Date/Time: Sat, 01 Feb 2025 21:56:00 +0000
auto flatten and cancel didn't work
View Count: 827
[2019-08-09 14:03:23] |
User229561 - Posts: 3 |
I had a wheat position that somehow stayed open after the close. I have my trade contract set to "flatten position and cancel orders" for just after noon mountain time. However, my position did not flatten and I got docked with my prop firm. Any ideas why this position didn't flatten? Now I can't trust that the positions wont automatically close unless I manually do it. No bueno
[2019-08-09 17:49:59] |
You can have absolute trust that anything automated is always going to work properly. There could be user error or other reasons. Perhaps it was triggered earlier in the same day and did not trigger again. Although in this case as long as you change the time to a more forward time it will then reset itself and trigger again in the same day. And also check the Trade Activity Log to see if the order was actually submitted but perhaps rejected: Trade Activity Log: Viewing Historical Trade Activity The other question is whether the chart or Trading DOM, the Trade Window you set this on was actually open and Sierra Chart was connected to the data feed. And were you also using this functionality here?: Basic Trading and the Trade Window: A >> Flatten And Cancel at Set Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-09 22:02:46
[2019-08-09 22:03:08] |
We made a correction to the above. : The other question is whether the chart or Trading DOM, the Trade Window you set this on was actually open and Sierra Chart was connected to the data feed.
The Trade Window itself did not have to be open but the chart definitely does. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-09 22:03:23
