Date/Time: Sun, 13 Sep 2026 22:31:22 +0000
denali dom
View Count: 1963
[2019-08-08 23:26:58]
zippyzip - Posts: 310
why is it missing orders compared to cqg ? we even put those orders on cqg dom and there not showing fully on denali
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=30614
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=30615
[2019-08-08 23:27:29]
There are two possibilities. The CQG depth is inaccurate which is a very strong possibility.
Or CQG could be merging in what is called implied depth. The CME provides two levels of implied depth. In about a week we are going to merge in the implied depth. But only for the top level. Not for the second level for performance reasons. But eventually we can get to the second level.
However, if you see differences from level 3 through 10, then CQG is absolutely wrong. We can say that with total confidence. Unless it happens to be the CME is giving out more than two levels of implied depth but their specification is quite clear on that. It is two levels.
If you see differences after 10 levels, if you are on the Denali feed, then we can also say with confidence CQG is wrong as well. Because we have absolutely no packet loss on that feed and we are processing the market by order data correctly.
Reference:
https://www.cmegroup.com/confluence/display/EPICSANDBOX/MDP+3.0+-+Consolidating+Implied+and+Multiple+Depth+Books
We will also get out the 500 levels, in about a week. That should not be a problem at all.
Date Time Of Last Edit: 2019-08-08 23:34:26
[2019-08-09 02:38:22]
ok i understand but i also checked it to other doms and they all lined up too , and next the volume on the number bars seems off as well but matches up in different data types , pic 1 is 3 diff doms with denali in the middle then pic 2 is mis match of volume from cqg to denali and its all less volume not more .
Private File
Private File
[2019-08-09 04:28:24]
You can do all of the comparisons you want and you do not have to trust us. The market depth data we provide is accurate. You are never going to convince us otherwise. That is straight off of the CME multicast feed . The only potential variation has to do with the merging of implied depth at the first two levels. But you see a difference at level 3.
The others are just simply wrong especially when you are looking at levels 3 through 10 and up.
In regards to the second screenshot, the reason you see some variation when you are looking at CL with data feeds that break up the summary trades into the individual sub trades is because there is variation in the algorithms used to generate the sub trades. When this was looked at back in 2017, CQG was always the outlier as compared to various other feeds we would compare to.
So CQG is not consistent with how everyone else is doing this. They are wrong once again.
And for proof, look at this comparison of data for CLU19 for August 8 from another trusted source:
IQ Feed:
Thu 2019-08-08 00:00:00.000 Begin Time
Region 1
QCLU19 1 Day #1 ()
Price Chg: -0.15
Open: 52.58
High: 53.06
Low: 51.94
Last: 52.43
Volume: 483242*
# of Trades: 338783*
OHLC Avg: 52.50
HLC Avg: 52.48
HL Avg: 52.50
Bid Volume: 242857
Ask Volume: 240385
Denali Exchange Data Feed:
Region 1
CLU19 1 Day #1 ()
Price Chg: -0.15
Open: 52.58
High: 53.06
Low: 51.94
Last: 52.43
Volume: 483242*
# of Trades: 338786*
OHLC Avg: 52.50
HLC Avg: 52.48
HL Avg: 52.50
Bid Volume: 242863
Ask Volume: 240379
The key is to look at the total volume and the number of trades and that validates all of the data that goes into Numbers Bars because this is an Intraday calculation, and the values across the Numbers bars for the entire day will equal the volume total shown above. As you can see our data feed matches IQ Feed exactly with volume.
You will see consistency though most likely with futures markets like ES when comparing to CQG.
Also make sure that you are using a 1 Tick intraday data storage time unit:
Thank you for demonstrating how substandard the CQG data feed is.
And one final note about CME market depth is that we follow the CME specification where depth is not transmitted out or considered valid until all of the depth updates in a message are processed.
You also need to understand an order for us to provide CME data, we have to complete their certification and we passed their tests. And they run through multiple iterations where we have to submit to them, the actual depth values received off of the multicast feeds.
The other type of validation that we do is we will compare the volume at each price level like you see in this chart image:
http://www.sierrachart.com/image.php?Image=1565331990835.png
We compared to IQ Feed and there was a 100% exact match for 2019-08-08. We consider IQ Feed a reference data feed. We normally do not use CQG for reference purposes.
Date Time Of Last Edit: 2019-08-09 10:04:56
[2019-08-09 11:46:02]
once again you take it personal like i am attacking you , i am on your side , im just trying to find whats best for our team that uses it. please try to learn to work with the people that are on your side looking to help and better your products experience .thank you for the explanation .
