Date/Time: Fri, 26 Apr 2024 10:53:35 +0000
Trading commands on custom control bar using different trade symbol
View Count: 883
[2019-08-08 14:51:49] |
AKR - Posts: 523 |
When doing that the buttons on the control bar dont work. guess they want to "cancel" or "flatten" the original symbol. as that something that might be changed? |
[2019-08-08 17:51:52] |
We are not understanding this. You are going to have to be much more detailed about this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-08 17:52:00
[2019-08-09 14:09:23] |
AKR - Posts: 523 |
OK, I have a customized control bar with trading buttons like "flatten" and "cancel all". The charts are set to ES and "trade and current quote symbol" to MES (use as trade only). When I am in an MES order and press the flatten button it does not react at all (so not to MES). Guess it wants to flatten a ES order which I dont have at that moment. |
[2019-08-13 23:04:12] |
When I am in an MES order and press the flatten button it does not react at all (so not to MES). Guess it wants to flatten a ES order which I dont have at that moment. It will in this case be flattening the position for MES assuming one exists and you can see that position on the Trade Window for the chart.Most likely the issue you had today was related to a TT order routing issue on the TT side. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-13 23:04:57
