Date/Time: Sat, 01 Feb 2025 21:49:19 +0000
[Programming Help] - Extracting sums of bid ask volumes only from Range 3 value
View Count: 757
[2019-08-08 08:56:19]
User164231 - Posts: 278
Hello fellow SC power users,
How do I extract only the bid x ask of Range 3 values and sum it up in two rows for a respective 5 min bar?
Example;
Range 3 = 5000 x 2500
Date Time Of Last Edit: 2019-08-08 08:56:55
imageExtracting values only from Range 3.jpg / V - Attached On 2019-08-08 08:48:30 UTC - Size: 124.38 KB - 301 views
[2019-08-08 17:29:55]
This has to be programmatically done with ACSIL:
ACSIL Programming Concepts: Accessing Volume at Price Data Per Bar
[2019-08-09 17:29:29]
Thanks. Could you point me to the right direction to learn ACSIL programming?
[2019-08-09 17:59:13]
Have a look at this page:
Advanced Custom Study Interface and Language (ACSIL)
And also to this section:
Advanced Custom Study Interface and Language (ACSIL): C++ References
[2019-08-10 05:30:23]
thanks. Lastly, is there a study to sum up a value of session bid vs ask? Example total for session = -11000 contract
[2019-08-10 10:19:50]
Ackin - Posts: 1865
Your question is not clear to me, working with volume is not difficult and I can do it to you, but I need to know what you need.
Try this:
Cumulative Sum of Study
one for Ask + One for Bid
and then
Study Subgraphs Subtract/Difference
Other way:
Cumulative Delta Bars - Volume
