Date/Time: Sun, 24 Nov 2024 20:49:50 +0000
Position Quantity (J5 in the Spreadsheet) does not seem to work properly
View Count: 1089
[2013-12-06 16:54:14]
User18601 - Posts: 31
Since I have installed version 1059, the J5 cell in the spreadsheet seems to be always set to 0 (zero). Additionally, in the chart the line which indicates the open position value does not appear when you have a position open.
[2013-12-09 08:13:32]
According to the Technical note you have just issued, the problem I refer in my previous post seems to be solved.
