Date/Time: Sat, 01 Feb 2025 22:04:59 +0000
Pivot Point - Variable Period R4.5 (SG30) and S4.5 (SG31) do not work at all
View Count: 687
[2019-08-07 16:47:27]
User122596 - Posts: 2
They do not appear on the chart. They provide 0.00 in the TVW. They appear as 0 in the spreadsheet.
Version 1957 64-bit (27856M)
Date Time Of Last Edit: 2019-08-07 16:49:48
[2019-08-07 18:47:20]
This would mean they are not supported by the particular Formula Type being used.
[2019-08-07 18:55:28]
It is set to the default formula 0.
R.5, R1.5, R2.5, R3.5 all work
S.5 S1.5 S2.5 S3.5 all work.
R1, R2, R3, R4, R5, R6, R7, R8, R9, R10 all work.
S1, S2, S3, S4, S5, S6, S7, S8, S9 , S10 all work.
Every single one works except R4.5 S4.5 which were the ones that were most recently added and obviously never tested.
R4.5 S4.5 are the only ones that don't work.
Date Time Of Last Edit: 2019-08-07 18:58:18
[2019-08-07 21:48:28]
John - SC Support - Posts: 37656
The support and resistance lines for 4.5 were only added for formula #5. Therefore they will not work on any other formula, they will only return 0, as you have seen.
You will also see this in the list of Support and Resistance lines for each calculation type in the documentation found here:
Pivot Points: Formula Types
