Date/Time: Sat, 01 Feb 2025 21:48:36 +0000
resetting orders on dom
View Count: 1426
[2019-08-07 16:37:55] |
leftguard90 - Posts: 6 |
i have adjusted my orders to not reset in the dom. I'm having a hard time trying to find the button or setting that can change it back where it will reset after i close or modify my position
[2019-08-07 18:59:14] |
When you say reset are you referring to orders being canceled? We are not understanding this. Maybe you are referring to this: Basic Trading and the Trade Window: Main/C >> Menu >> Orders >> Cancel Orders on Flat Position (chart specific) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-07 21:51:18] |
John - SC Support - Posts: 37656 |
Are you referring to this setting: Global Trade Settings Windows: Clear Current Bid/Ask Volume on New Position (Global Settings >> Chart DOM Settings >> Other >> Other Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-07 22:11:42] |
Maybe better question is how do I turn on and off my attached order quickly without hovering my mouse over to it
