Date/Time: Sat, 18 May 2024 07:58:01 +0000
right-clicked to exits current drawing tool default to Hand tool instead of pointer tool
View Count: 1093
[2019-08-07 12:14:59] |
User987214 - Posts: 2 |
Is there a setting that makes my default tool hand tool instead of pointer? I would like to keep both 'right-clicked to exits current drawing tool' on and 'keeps me in the current drawing tool after a single-use' on.
Date Time Of Last Edit: 2019-08-07 12:21:58
[2019-08-07 19:22:12] |
The way this works is that when you right-click to cancel the current active drawing, the current tool remains selected. It will not change.
[2019-08-08 11:54:06] |
I'm afraid you have mistaken right-clicked to exits current drawing tool and enable delete selected drawing with right-click. When I exit drawing mode, it jumps to pointer even if I use hand tool before entering into drawing mode. hand tool -> draw ray -> draw another ray -> right-click to exit drawing mode -> jump to pointer I want hand tool -> draw ray -> draw another ray -> right-click to exit drawing mode -> hand tool is this possible? Date Time Of Last Edit: 2019-08-08 12:02:05
[2019-08-10 02:26:14] |
We will have to add some new options to control this. This does not currently exist.
[2020-02-04 06:55:07] |
What you are looking for will be supported in the next release of Sierra Chart through a new setting.
