Date/Time: Sat, 01 Feb 2025 21:55:03 +0000
Biftinex data
View Count: 661
[2019-08-07 08:14:39] |
Gregoire - Posts: 2 |
Hi, Why the date range only goes to 2019-07-30 in the chart settings for Biftinex? Do you stop supporting it or is it because i'm in free trial? |
[2019-08-07 10:26:11] |
That will be the case with some Bitfinex symbols. Consider the Bitfinex feed unsupported.
[2019-08-07 10:47:17] |
Ok, and do you plan on adding other high volume exchanges market like Binance or Okex ?
