Date/Time: Fri, 07 Mar 2025 21:52:18 +0000
Transact
View Count: 1098
[2019-08-06 16:28:21] |
ETAI ZVI MOSHE - Posts: 1 |
Hey, My broker is TransAct. I just finished talking to them, and my problem isn't "denali". I have through my broker access to CME group and market depth real time data. my problem is that sierra charts won't login to my transact account. I get repeatedly this message : "TransAct WS | Account logon error: -1(-1) | 2019-08-06 18:10:33.505" I have talked to TransAct through skype, and they confirmed I gave the right account name,password,and account number. I hope you can help figure this situation out. currently my problem is connecting between the 2 software's. the TransAct account is connected to the data and everything is ok with it. Thank you |
[2019-08-06 16:56:36] |
User657944 - Posts: 173 |
HI, I'm also a Transact User try to load back to 1941 version that is the only one working fine for trading, till the situation with the websocket will be resolved. If that version is not working than you have a specific issue. |
[2019-08-06 17:09:40] |
In regards to post #1, we will contact Transact for you. This has been done. They will need to resolve this for you.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-06 17:11:51
[2019-08-06 17:28:19] |
Transact said the problem at post #1 has been resolved for you.
