Date/Time: Sat, 01 Feb 2025 21:57:48 +0000
chart + profile
View Count: 1265
[2019-08-06 15:08:52] |
User00111 - Posts: 111 |
You could give me some suggestions to build the chart attached with the side profile -- A. |
ES_Chart.png / V - Attached On 2019-08-06 15:08:30 UTC - Size: 73.18 KB - 539 views |
[2019-08-06 15:14:15] |
ticinotrader - Posts: 401 |
Drop me a message with your Sierra Account name and I send you this chartbook.
[2019-08-06 15:20:02] |
universaltrade -- A |
[2019-08-06 16:25:43] |
The chartbooks are sent. you may receive a notification about the incoming files: TicinoTrader-Advanced-TT-Footprint.cht Crude-Footprint-v1928.Cht They will be automatically placed into your SierraChart\Data folder and you can open it using File -> Open Chartbook. |
2019-03-31_113832.png / V - Attached On 2019-08-06 16:24:37 UTC - Size: 257.98 KB - 478 views 2019-06-10_183319.png / V - Attached On 2019-08-06 16:24:53 UTC - Size: 177.86 KB - 550 views |
[2019-08-07 05:00:02] |
Let us know if any further help is needed here.
