Date/Time: Sat, 01 Feb 2025 21:43:27 +0000
regression analysis not loading
View Count: 617
[2019-08-06 14:49:35]
User677916 - Posts: 4
Error determining study collection version. Code = -1364283902 | 2019-08-06 14:11:31.374 *
This study collection file requires a newer version of Sierra Chart. To update select Help >> Download Current Version or Prerelease. | 2019-08-06 14:11:31.374 *
Error determining study collection version. Code = -1364283902 | 2019-08-06 14:31:22.574 *
This study collection file requires a newer version of Sierra Chart. To update select Help >> Download Current Version or Prerelease. | 2019-08-06 14:31:22.574 *
I have tried to download current version and prerelease version. both downloads were successfully installed. Also restarted the computer.
When trying to load regression analysis the same message shows and will not load.
Thank you
[2019-08-06 18:33:11]
It sounds like you are you wanting to use a Study collection file provided by someone. But based on that message it looks like that file is corrupt in some way or not a Study Collection file.
Have them send you that file again by using this feature:
File Sharing
[2019-08-06 18:59:41]
It is from Andre Minassian at Intuitive trading institute.
Was working fine for over a year. How would the file be corrupted now
[2019-08-06 19:52:25]
We do not know. Have them send you the file again using this method:
File Sharing
[2019-08-06 23:21:11]
Yes you were correct the file had an issue. I downloaded it again from the original file and its working now.
Thank you
