Date/Time: Sat, 01 Feb 2025 22:11:21 +0000
Number FOrmatting
View Count: 659
[2019-08-06 13:14:07]
User752087 - Posts: 5
Hi, in Number Bars calculated value, I would like to change the formatting of the number (e.gl Total Volume 823648 - i would like to see it as 823.648)
is there a way to do this?
thanks
[2019-08-06 17:46:39]
This is not supported.
However, you can use this Input with Numbers Bars for large number formatting:
Numbers Bars: Use Large Volume Number Formatting
Date Time Of Last Edit: 2019-08-06 17:47:38
