Date/Time: Sat, 01 Feb 2025 21:53:42 +0000
Cannot access HKFE Index real time data - Account Support Ticket
View Count: 624
[2019-08-06 11:50:09] |
Polly Chow - Posts: 1 |
Hi Customer Support Team, I've just opened up a new account and using my friend's charts (also real time Sierra Chart HKFE data). However, when I've copied his charts into my Sierra Chart (they can all open up) they just open but do not have real time data connection. I've paid for all monthly services already with autorenewal. May I ask what actions/settings I've missed that I need to set to get real time data on HKFE Futures pls? Many thx! Polly |
[2019-08-06 16:39:04] |
John - SC Support - Posts: 37656 |
You need to finish the setup for the Sierra Chart Exchange Data Feed. Start at Step 7 of the Setup Instructions and finish them up. You will find the Setup Instructions here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-06 17:19:51] |
And you also need to activate the Hong Kong Futures Exchange. That has not been done either. And be sure to refer to the prior post as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
