Date/Time: Thu, 10 Sep 2026 18:24:07 +0000
Name and Value label subgraphs
View Count: 1652
[2019-08-05 19:47:35]
User310898 - Posts: 43
When I load a study onto my chart and choose to set a name and value label within "subgraphs" both as Horizontal align "Left Edge" they overlap on top of each other as attached ("54.67" overlaps on top of the name "Sierraa Charts").
If I do the same with a horizontal line (green writing underneath it) it shows the "Name Label" first then it shows the "Value Label" next to it without overlapping. Which makes more sense. Maybe this was an oversight, is it possible to amend it so they do not overlap when I do that within the subgraph section and actually do what the horizontal line does, ie Name Label, then Value Label without the overlap if I select "Left Edge" for both?
Private File
Private File
Private File
[2019-08-08 05:05:55]
What you want is not supported. Subgraphs are very different than drawing tools. This is not going to change. It does not make technical sense, and it is very very complex and has lots of associated problems.
Date Time Of Last Edit: 2019-08-08 06:39:37
[2019-08-08 06:36:01]
OK no problems, that is good to know anyway.
