Date/Time: Sun, 24 Nov 2024 23:14:18 +0000
[User Discussion] - volume oscilator
View Count: 1832
[2013-12-05 22:38:37]
maruska11 - Posts: 7
Hello. How do I get volume oscilator where I can plot parameters for slow and fast volume? I need one that doesn't copy price like volume zone oscilator does.
[2013-12-06 04:41:12]
vegasfoster - Posts: 444
I am not understanding your request, can you rephrase or post a pic of what you are looking for?
[2013-12-10 23:16:37]
On the left is volume oscillator in Ninja trader that I'm trying to recreate. It's the blue line oscillator with white MA over it under the price /please ignore the histograms/. It has parameters 34 for slow and 21 for fast. On the right is my sierra chart with volume oscillator parameter 34 /since I can plot only one parameter/. It's the same day and both volume oscillators are looking different. How do I achieve my volume oscillator look the same by plotting slow and fast.
attachmentvolume1.docx - Attached On 2013-12-10 23:08:21 UTC - Size: 277.96 KB - 609 views
[2013-12-11 06:46:48]
The easiest way would be for you to post the indicator here so I can see the code directly and convert it for you.
[2013-12-17 14:02:12]
This is what I was able to get from Ninja trader user. Hope that is the code you are looking for. I appreciate your help.
attachmentVOLUME OSCILLATOR CODE.docx - Attached On 2013-12-17 14:00:46 UTC - Size: 21.35 KB - 722 views
[2013-12-19 05:51:26]
I looked at it and it's just a macd based upon volume using a simple moving average. Just apply the regular MACD to your chart, change the input to volume, and change the moving average type to simple moving average.
