Date/Time: Sat, 01 Feb 2025 19:54:35 +0000
Tick Chart / Range Bars
View Count: 1619
[2019-08-05 11:37:01]
User660345 - Posts: 18
Hello can you please tell me how to set a tick chart? I have the live data from Interactive Brocker and can only set "Range Per Bar" in Chart Settings?
Thanks for your answer and best regards,
[2019-08-05 19:19:22]
John - SC Support - Posts: 37656
In Chart Settings >> Bar Period Type select Number of Trades per Bar, then set the Settings right below that to 1. Refer to the following documentation:
Chart Settings: Intraday Chart Bar Period >> Bar Period Type >> Number of Trades Per Bar (Chart >> Chart Settings menu)
