Date/Time: Fri, 29 Mar 2024 13:13:53 +0000
Zig Zag Text Alignment
View Count: 1074
[2019-08-05 11:14:29] |
User476926 - Posts: 56 |
Is it possible to get "right aligned" text rather than default "left-aligned" on zig zag study? When price is on right hand side of chart, would be cleaner to view.
[2019-08-11 12:10:06] |
Just bringing back to front, and to clarify, this is when using text on multiple lines (zigzag showing: reversal price + tick distance + volume).
[2019-08-15 09:42:48] |
We will see about adding text alignment options.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-15 09:42:53
[2019-08-15 19:01:30] |
John - SC Support - Posts: 30445 |
We have added options for both Single Line and Multi-Line Horizontal Alignment. You can choose between Left, Center, or Right. This will be in the next Pre-Release - version 1976 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-16 11:00:20] |
Brilliant, thanks.
