Date/Time: Tue, 06 Oct 2026 12:13:19 +0000
Send text to chart with ACSIL
View Count: 1704
| [2019-08-05 09:32:44] |
| User462086 - Posts: 203 |
Hi, according to the following link, it's possible to change a study's input value from the chart. I'd like to do this from a custom ACSIL study rather than the keyboard. Is there a native Sierra Chart function that can send text to the study chart's window (regardless of its state:active,inactive,not visible)? Or do I need to use something like the C++ SendMessage? Chart Studies: Changing Study Inputs Directly from Chart Many thanks!! |
| [2019-08-05 09:34:31] |
There is a very direct way to do this from a custom study. Refer to: ACSIL Interface Members - Functions: sc.SetChartStudyInputFloat() There are also two other functions for integers and strings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-05 09:34:41
| [2019-08-05 09:38:14] |
Wonderful! Thanks for the speedy response!!
| [2019-08-05 09:48:25] |
Just a quick follow-up question. I see the above will work for studies, how about for Intraday Bar Periods accessed from the 'Chart Settings' dialog box? For example, let's say I have a 1000 volume bar chart that I'd like to change to a 2500 volume bar chart from within a custom ACSIL study. Many thanks!! |
