Date/Time: Sat, 01 Feb 2025 22:05:19 +0000
Shading Between Lines
View Count: 1078
[2019-08-05 07:27:25]
User476926 - Posts: 59
How do I shade between 2 study lines? Tried Study Subgraph Reference, which draws the shading but is hugely offset from 2 lines in a different part of main chart window (ie not even close to being between the 2 lines)? Using v1964. Thanks.
[2019-08-05 09:25:21]
Make sure the Study Subgraphs Reference has a Scale Range of Automatic:
Chart Scale and Scale Adjusting
Date Time Of Last Edit: 2019-08-05 09:25:48
[2019-08-05 10:52:41]
Right - I use Constant Range for scale. Anything I can use for shading?
[2019-08-05 14:52:21]
That should be fine.
Provide that chart by following these instructions here:
[2019-08-06 10:08:33]
File attached. Trying to shade between S1 and S2 in blue with Reference Study. Shading is visible but not between lines, using constant range scale.
Private File
[2019-08-06 15:49:14]
John - SC Support - Posts: 37656
You just need to set the Scale for the Study Subgraphs Reference study to Automatic. This will move the shading to the right position for the chart. Refer to the information here for how to set the scale for a study:
Chart Scale and Scale Adjusting: Opening the Scale Settings Window For a Study
[2019-08-06 19:19:59]
Perfect. Huge help. Thanks.
