Date/Time: Sat, 01 Feb 2025 19:39:55 +0000
limiting chart's date range in a vacuum
View Count: 544
[2019-08-04 11:28:00]
nus1 - Posts: 39
Hello Sierra team,
Is it possible to adjust "To:" range in chart settings, below "Date Range in File(yyyy-mm-dd):"
I am trying to make chart's date range limited to a specific date(w/o further updates) for hindsight back test/filing/easy access purposes.
Thank you.
Date Time Of Last Edit: 2019-08-04 12:00:29
[2019-08-05 05:03:43]
Yes this is supported but you need to use this particular setting:
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#UseDateRangeFromTo
