Date/Time: Mon, 14 Sep 2026 04:17:04 +0000
Combo Tool of Alt+H and Alt+3?
View Count: 1159
| [2019-08-03 23:59:49] |
| User218474 - Posts: 8 |
Tradingview's default tool acts as both as crosshair (Alt+3) and a scroll tool (Alt+H). Can these be combined into a dual-purpose tool? This functionality is quite common and it's cumbersome to constantly be switching between the selection and scrolling tools |
| [2019-08-05 22:05:33] |
This is actually currently supported. Here is the documentation for this: Chart Drawing Tools: Chart Values Tool Always on When Using Hand Tool Let us know if you need further help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-08-06 19:07:16] |
Wonderful! The only other piece of functionality I'm having trouble finding for this: Is there a way to have the OHLC values on the top of the chart change to reflect the cursor position as it moves? Rather than only reflecting the most recent visible candle. |
| [2019-08-06 20:42:21] |
| John - SC Support - Posts: 47854 |
No, it is not supported to change the data that is at the top of the window to reflect the location of the cursor. The Tool Values Window exists in order to give you this information, and there is also the Compact Tool Values window, which can also be made Horizontal, so it can be placed in a position at the top of the chart to give you the information you are looking for. Refer to the documentation starting here, and through the next section for what you need: Chart Drawing Tools: Tool Values Window For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
