Date/Time: Sat, 01 Feb 2025 22:00:11 +0000
Number Bars
View Count: 1045
[2019-08-03 14:47:11] |
User103636 - Posts: 4 |
Hello, I went to the Number Bars, Column 1 set the Bid X Ask so that I see the inballance To do this, I set Column 1 Range 0 Up / Down Color to white and Column 1 Percent Compare Thresholds to 2.5, 3, 4. Under Column 2, I've created a volume profile, Based on AskVol / BidVol Percentage. Here I have not colored the colors of the Range 0 Up / Down Color in white, also I have other values under Percent Compare Thresholds (0.25, 0.5, 0.75) So far, I have exactly what I want, to which I would like to have both in a column. Is it possible to overlap these? Kind regards |
Unbenannt.PNG / V - Attached On 2019-08-03 14:46:39 UTC - Size: 23.46 KB - 320 views |
[2019-08-04 06:56:35] |
mpro - Posts: 44 |
You can use something like 0.25,0.75,4. Then change "Use separate Colors for Text Coloring Method" In: 103. Change Range 0-2 Color for Text to white (In: 105-110).
Footprint_Volumeprofile_Imbalance_1_0.png / V - Attached On 2019-08-04 06:55:58 UTC - Size: 41.19 KB - 388 views Footprint_Volumeprofile_Imbalance_1_0+.StdyCollct - Attached On 2019-08-04 06:56:09 UTC - Size: 18.84 KB - 356 views |
[2019-08-04 10:44:18] |
User907968 - Posts: 825 |
As an alternative, you can add a 2 copies of numbers bar study, then you are able to use 'Column 1 Percent Compare Thresholds' exactly as desired for each.
NB_VP .StdyCollct - Attached On 2019-08-04 10:43:35 UTC - Size: 28.16 KB - 259 views |
[2019-08-05 16:08:14] |
John - SC Support - Posts: 37656 |
User103636 - Let us know if you have the information you need. If you still need something else related to this, let us know precisely what you are trying to accomplish that you have not been able to do, and we will direct you to what you need.
[2019-08-07 01:23:48] |
ok, thank you both good ideas work, I have opted for another number bar
