Date/Time: Sat, 01 Feb 2025 19:30:28 +0000
1 min change
View Count: 771
[2019-08-03 10:46:20]
User872457 - Posts: 3
Hi, I am interested to have 1 min change for the list of the stocks. Is it possible to create a formula for qoute spreadsheet to get 1 min change. Thanks!
[2019-08-03 11:50:47]
For this you just need to use a 1 minute per bar chart and then utilize the Bar Difference study on that:
Bar Difference
[2019-08-03 12:05:35]
Thanks for the reply, but I need it for the list of stocks, say 20 stocks in one sheet, to see them simultaneously and have ability to sort. Thanks
[2019-08-03 12:33:22]
For this, have a look at using the Study Summary window:
Study Summary Window
Although it does not support sorting.
[2019-08-03 13:12:45]
Any idea with sorting? Thanks!
[2019-08-03 13:51:30]
Sawtooth - Posts: 4164
I use the Study Summary Window and it can be sorted by clicking on a column header.
[2019-08-05 14:49:33]
Yes actually we forgot about that, it does support sorting.
We will add a separate subsection on that page in regards to sorting.
