Date/Time: Sat, 01 Feb 2025 18:43:33 +0000
Trading dome
View Count: 648
[2019-08-02 20:23:31] |
Gerald L Reynolds - Posts: 7 |
IT MAY NOT MAKE ANY SENSE TO YOU THAT THE TRADING DOME DISAPPEARS WHEN TRYING TO MAKE A TRADE OR IS NOT SAVE, BUT THAT IS WHAT HAPPENS
[2019-08-03 01:24:13] |
Infinite - Posts: 134 |
always make sure you have "always on top" checked on the DOM.
[2019-08-03 01:40:30] |
This is in response to this particular support request here: Trading dome We did ask if there is an abnormal shutdown of Sierra Chart itself. Are you able to consistently reproduce the problem so you can show us? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
