Date/Time: Sat, 01 Feb 2025 19:56:59 +0000
Is there a way to preserve values of Quantity Buttons in Trading window?
View Count: 976
[2019-08-02 15:24:33] |
User972768 - Posts: 166 |
Hello, I'm trading different setups/configurations (OCO orders) through the day and often switch them via dropdown list on top of the Trading window. What I've noticed is that even if I configure Quantity buttons to be 1,3,6,9,12 as soon as I switch to another configuration, they all reset to default values of 1,2,3,4,5,6 I also watch market via different charts and have my Trading windows attached to some of them. It seems that charts do not share configuration of the buttons either. Hence it becomes very frustrating and time consuming to adjust these buttons on each chart. My settings also tend not to be preserved through application restart. I use compact view of the Trading Window, if it makes any difference. Is there a way to save configuration of these buttons, so I don't have to reconfigure them on application restart / change of OCO configuration? Thanks and best regards |
[2019-08-03 12:43:18] |
The Trade Window button quantities are saved with a trade window configuration. However, there is this option: Basic Trading and the Trade Window: Main/C >> Menu >> Settings >> Ignore Quantity on Load Configuration My settings also tend not to be preserved through application restart. This cannot possibly be true at all so long as you have saved the Chartbook.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-03 12:43:38
[2019-08-05 13:01:45] |
Thank you. That explains it. I saved my OCO configurations when 1st started to use Sierra. I didn't pay too much attention to the quantity buttons back then. Thanks again |
