Date/Time: Mon, 25 Nov 2024 01:53:01 +0000
How to create a "composite", ie a graph that is derived from a ratio of two stocks or indices.
View Count: 1516
[2013-12-05 17:13:12] |
bercor - Posts: 30 |
Hello I would like a graph derived from the ratio of two databases. This "composite" I would like to have it as a traditional title or to put in place a marker on the underside of a graph. Example 1 I would like to create a graph resulting from the division of the NYSE and NASDAQ Nasdaq / Nyse = new graph (main graph) that can be managed as a normal graph of shares or futures in which I can insert averages indicators etc etc. 2nd example I would always create a graph resulting from the division of the NYSE and NASDAQ Nasdaq / Nyse = that can be inserted as if it were an indicator of another main chart. as if it were then an indicator I would be if I garto you indicated the methodology to achieve this'. thanks in advance Date Time Of Last Edit: 2013-12-05 17:15:22
[2013-12-06 04:15:07] |
This can be done by using the Ratio study: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s5 Refer to this page to work with studies: http://www.sierrachart.com/index.php?l=doc_ChartStudies.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-12-11 17:35:19] |
Thanks for reporting the two links but despite trying for hours to get what 'you told me, I can not. Can you please help myself? I just can not set the Graph 1 and Graph 2 et obtain the relative strength. thanks |
[2013-12-11 19:09:56] |
TastyRisk - Posts: 119 |
1. To import the NASDAQ graph try Study/Price Overlay (fill blanks = Y). Hide the study or set into region#2. 2. Then use the Study Subgraphs Ratio. Study 1 = NYSE. Study 2 = NASDAQ. Display it in region#2 or #3. 3. You can then base a new relative strength study on Study Subgraphs Ratio and set to use the same region and scale "same as base graph". Date Time Of Last Edit: 2013-12-11 19:13:22
[2013-12-13 18:05:33] |
We can create a Chartbook for you that uses the Ratio study between two charts. Can you give us the particular symbols you want to create a ratio of. And let us know what Data/Trading service these are for. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-13 18:06:08
[2014-01-02 17:05:19] |
Thank you so much! Whether a TASTYRISK both the staff of SC. I would like to get for example the ratio of Apple (AAPL) with the NASDAQ index. THE report obtained I would like to use it as a main graph to add indicators etc etc or in the lower part of the window below the graph we APPLE, APPLE or in the same window. I thank you if you will help me as I have proposed. Date Time Of Last Edit: 2014-01-02 17:05:50
