Date/Time: Thu, 10 Sep 2026 09:01:33 +0000
Trade window missing
View Count: 2360
[2019-08-02 13:53:05]
User459170 - Posts: 262
Trade window doesnt show up unless attach to chart option is chosen. If open trade window is clicked nothing happens.
Is it not better for you to delay the updates to new versions than put out a version that messes up stuff which was solid earlier?
Date Time Of Last Edit: 2019-08-02 14:26:32
[2019-08-02 16:36:07]
John - SC Support - Posts: 47822
Select Chart >> Reset Child Windows. Then select Trade >> Open Trade Window for Chart, and the Trade Window will open up in the upper left-hand corner of the chart window.
Refer to the following documentation:
Chart Menu: Reset Child Window (Chart menu)
[2019-08-02 18:47:50]
Your conclusion is wrong. This is not an issue in the new version. Follow the instructions in post #2 above.
Date Time Of Last Edit: 2019-08-02 18:48:07
[2019-08-08 05:09:49]
User493842 - Posts: 24
I've had a similar issue where my trade window fails to appear. I have reset the windows but alas still nothing. I am on version AT 1967. I can attach a trade window to a chart but prefer it to be separate so any help greatly appreciated.
[2019-08-08 07:07:47]
You need to select Chart >> Reset Child Windows. Refer to:
Basic Trading and the Trade Window: Trade Window is Missing or Does Not Appear
