Date/Time: Sat, 01 Feb 2025 22:02:10 +0000
micros
View Count: 940
[2019-08-01 23:02:22] |
User479983 - Posts: 3 |
Hello, why I can’t trade micros? I use Sierra Charts with rithmic-data. I’ve choose the symbol from the list in Sierra. The chart displays the symbol. It must be correctly. The name in the list ist MESU19-CME Sierra transfers MES-201909 and then rithmic send the error-massage What means this? " Rejeded at RMS Product code not permissoned (MES)" Dosn't send sierra the right product-code? BR |
[2019-08-01 23:53:17] |
You need to contact your broker about this error message. They will take care of that for you. Give them the same message. Also, what do you mean by this: Sierra transfers MES-201909
This is not making sense to us. Where are you seeing that particular symbol? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-01 23:55:51
[2019-08-02 01:04:14] |
in attached pdf you can see
01-08-_2019_20-34-50.pdf - Attached On 2019-08-02 01:03:14 UTC - Size: 3.81 KB - 272 views |
[2019-08-06 00:54:28] |
That message box is from some other program. Not Sierra Chart. So whatever symbol format that other program is using is fine.
