Date/Time: Sun, 24 Nov 2024 20:24:00 +0000
Close a part of a position
View Count: 1973
[2013-12-05 16:23:36] |
User59474 - Posts: 13 |
Hi, Can you tell me how to close a part of my opened position without using the attached orders as targets.? for example 50k opened on buy EURUSD, and close 25k or 10k to take partial profit, without using a target point. Thanks |
[2013-12-05 18:06:53] |
Simply enter a sell order for 25K or 10K. Here are the instructions: https://www.sierrachart.com/index.php?l=doc/doc_TradeWindow.html#TradeWindow Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
