Date/Time: Sat, 08 Feb 2025 18:05:50 +0000
MOVETO_BE_ACTION_TYPE_OCO_GROUP_TRIGGERED - modify error shows in log
View Count: 871
[2019-08-01 17:23:15]
onnb - Posts: 662
We have an ACSIL trading study that enters with multiple OCO groups.
We use MOVETO_BE_ACTION_TYPE_OCO_GROUP_TRIGGERED
Snippet looks like this
order.MoveToBreakEven.Type = MOVETO_BE_ACTION_TYPE_OCO_GROUP_TRIGGERED;
order.MoveToBreakEven.BreakEvenLevelOffsetInTicks = 0;
order.MoveToBreakEven.TriggerOCOGroup = OCO_GROUP_1;
When 1st target gets filled, SC modifies and cancels the paired stop order at the same time.
So it generates a message in the log which users complain about:
Order modification failed | SC Futures Order Routing/Data order update (Order cancel/replace reject). Info: Order modification failed | Order is not in a working state. Order cannot be modified. Text: Attached order. Parent: xxxx. Internal Order ID: xxxx. Service Order ID: xxxxx. Symbol: CLU19_FUT_NYMEX. Account: xxxx | 2019-07-29 05:40:33.245 *
Does that make sense?
Date Time Of Last Edit: 2019-08-01 17:24:22
[2019-08-03 12:48:04]
We need some time to look this over. Please allow a couple weeks due to our workload.
[2019-08-06 01:32:16]
We have not gone through this in detail but thinking through this, we think that there is a modification of the Stop order in the OCO Group that has been triggered because there may just be a partial fill.
But we will continue to look into this.
[2019-08-06 02:51:01]
onnb - Posts: 662
Noted, I have some of the trade activity log if you need, just let me know.
[2020-07-21 21:11:38]
This should be resolved by now.
