Date/Time: Sat, 01 Feb 2025 19:00:24 +0000
Backtest deviations in the data feed
View Count: 623
[2019-08-01 13:52:22]
User993201 - Posts: 2
Hello SierraChart ,
I have the following problem :
The backtest with the same settings and the same data feed in the Bar Based Backtest Replay mode generally delivers drastically different results with the data feed Rithmic , CTS however is always the same. Do you have an idea ? It's very important for me because I have several automatic systems running and I can't explain where the differences come from. Are there any possible settings to ensure the accuracy of the replay - except accurate trading system backtest ?
many thanks for the answer
[2019-08-02 04:54:50]
We are not understanding this. There is no "bar based backtest replay mode".
[2019-08-02 07:05:47]
thought it was generally known the function ... "AutoTrade System Replay Backtest" is my test environment.
Thank you
[2019-08-02 10:41:10]
What are you comparing this backtest to where you are seeing an inconsistency?
