Date/Time: Sun, 19 May 2024 10:31:46 +0000
Change Trading DOM
View Count: 891
[2019-08-01 11:32:18] |
User572956 - Posts: 7 |
Is it possible to shorten the names to reduce the width of Trading DOM: 1) "Lmt" change "L" 2) "Stop" change "S" 3) if setting Profit/Loss Format = Do Not Display then do not output "P/L:" 4) Is it possible to make a cross near the open position? |
[2019-08-05 10:04:51] |
1,2. We will add this. 3. Yes, we need to document this. 4. Not sure we understand this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-05 14:51:27] |
screenshots
[2019-08-05 16:50:43] |
3. This is documented. You can remove the P/L: by deselecting (unchecking) this option: Global Trade Settings Windows: Display Profit/Loss On Position Line (Global Settings >> Chart Trade Settings >> General >> Trade Position Line) 4. There is no support for being able to close an open position by selecting an X in the position line. You have to close it by selecting Flatten, Reverse, or putting in an opposing order. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-06 05:36:51] |
1,2 add please
[2019-08-06 07:06:09] |
These will be out in about a couple of weeks.
[2019-09-09 20:14:47] |
User495158 - Posts: 106 |
#6 Any update on this?
[2019-09-10 08:10:33] |
There are many new options for what is displayed on the order line in the latest version of Sierra Chart in Global Settings >> Chart Trade Settings.
