Date/Time: Sat, 01 Feb 2025 21:56:15 +0000
Control Bar buttons have turned to text
View Count: 885
[2019-08-01 00:31:59]
User459170 - Posts: 262
All the buttons in my control bar have turned to text.
If I tried to change using set image, it has just button# how does one figure out what the icon is for horizontal line for example, do I have to go through each button#.bmp to figure this out?! Is there an easier way?
[2019-08-01 02:46:05]
We are still working on this. For now you just need to set the Caption/Image setting to Use Image in the Control Bar properties for the buttons where you want the default image. Refer to:
Control Bar: Control Bar Button Properties
But you should not have to do that and we are going to look into this, before morning.
Date Time Of Last Edit: 2019-08-01 02:46:19
[2019-08-02 13:54:38]
This is still not happening. When do you think it will be fixed?
[2019-08-02 14:28:17]
User844383 - Posts: 40
User459170
You can find the button bmp pictures in the buttons folder in your SC directory... ie C:\sierrachart\buttons
I just had to redo all of my buttons, took about 15 minutes.
Date Time Of Last Edit: 2019-08-02 15:02:16
[2019-08-07 10:29:14]
Usuario - Posts: 19
Same issue here.
All buttons turn into text.
[2019-08-07 19:36:11]
We have this resolved in the latest prerelease. You can update with Help >> Download Prerelease.
