Date/Time: Wed, 12 Feb 2025 15:40:11 +0000
Time Zone in ACSIL
View Count: 1279
[2019-07-31 20:47:14]
kas64h - Posts: 87
Is there a way of getting the Chart (or Global) time zone through ACSIL, and/or detecting a change in time zone?
I read in your response to the post 'Add parameter TimeZone to Time Line study', that 'ACSIL does have functions to do time zone conversions', so I'm guessing there's something, but I can't see what it is.
I'm aware of the ACSIL Chart Session Times variables and functions, but can't see anything relating to time zones.
[2019-07-31 21:32:36]
Ackin - Posts: 1865
check this:
sc.ConvertDateTimeFromChartTimeZone()
[2019-08-01 08:52:37]
Yes see if that function helps. Also refer to:
sc.ConvertDateTimeToChartTimeZone()
Date Time Of Last Edit: 2019-08-01 08:52:51
[2020-10-09 04:03:52]
User100912 - Posts: 104
Could you expose the Chart Time Zone setting to ACSIL please?
Use case: tracking Frankfurt, London, New York, Chicago instruments.
For convienience all instruments can be displayed on the same chart.
Time Zone Setting: Resolving Differences with the Transition To/From Daylight Savings Time in Different Time Zones
you must set either the Time Zone in the chart if you are using the chart specific Time Zone setting, or the Global Time Zone to the same time zone of the exchange where the symbol trades
Neither
sc.ConvertDateTimeFromChartTimeZone() or
seem to do what I need, which is to control the chart's time zone directly from ACSIL. (I've an ACSIL study which reads the instrument symbol and then sets paramters accordingly, and I'd like timezone to be one of those parameters.)
[2020-11-05 20:06:08]
This function will be added to the next Sierra Chart release:
sc.SetChartTimeZone (const int ChartNumber, const TimeZonesEnum TimeZone);
Date Time Of Last Edit: 2020-11-05 20:06:25
