Date/Time: Sun, 24 Nov 2024 20:43:12 +0000
can I share data between 2 computers?
View Count: 1275
[2013-12-05 13:38:50] |
bryden mg firth - Posts: 4 |
I'm running copy 1 of sierra charts on the first computer connected to T4 data service. I'm running copy 2 of sierra charts on a second network computer connected to sierra charts forex data. can I share T4 intraday chart data with the second copy? both copies are logged into sierra charts using the same user name and password. I looked through this page http://www.sierrachart.com/index.php?l=doc/MultipleServices.html and I'm still not clear if this is possible, do both copies have to be on the same computer? if this is not possible OK. if it is, I'm clearly doing something wrong, I just don't want to waste time if its not going to work. thanks very much. |
[2013-12-05 17:48:20] |
No. This not possible. They have to be on the same computer.
