Date/Time: Sat, 01 Feb 2025 19:03:43 +0000
Market Depth Heat Map blocking Volume at Price
View Count: 2127
[2019-07-31 16:31:59] |
User339484 - Posts: 71 |
http://www.sierrachart.com/image.php?Image=1564590515473.png On the right side you can see the space that the market depth is blocking. It only blocks when a large order is on the bid or ask. (sorry for report I had an error and went to delete it but it only deleted the message not the post) |
[2019-07-31 17:51:26] |
John - SC Support - Posts: 37656 |
The general resolution to this is to make sure that the Volume by Price study is lower in the list of studies than the Market Depth Historical Graph. This sets the order in which the studies are drawn, which will make the VbP drawn after (on top of) the Market Depth Historical Graph. Refer to the following: Chart Studies: Study Display Order But, the image you attached is confusing, as it looks like there is just the one bar extending into the fill space on the right. Is this the case, or is it just the image? Out of curiosity, on the Market Depth Historical Graph settings, what is the setting for Display Market Depth Quantities after Last Bar? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
