Date/Time: Sat, 01 Feb 2025 19:00:45 +0000
Performance with Version 1959 and Higher
View Count: 607
[2019-07-31 12:52:34] |
User93464 - Posts: 52 |
I'm on SC version 1962 and the lag in the charts is appalling. Even trying to select the Help function at the top of the chart takes 5 -7 seconds to respond and trying to move a drawing takes the same time or not at all. This is totally unacceptable
[2019-07-31 13:02:19] |
TedMar - Posts: 190 |
check this Significant Lag past version 1958
[2019-07-31 13:53:04] |
I have reverted back to version 1957 and everything now works as it should. The issue is SC software related post version 1957
[2019-07-31 17:27:32] |
For more information, refer to: Managing Performance with Version 1959 and Higher and the Chart Update Interval Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
