Date/Time: Sat, 01 Feb 2025 19:05:19 +0000
startup 1941 build
View Count: 571
[2019-07-31 11:35:25] |
Yeager - Posts: 129 |
When I strartup SC from the tool bar icon its the 1918 build, however if I dump that icon and startup the 1941 from the SC system folder, then keep this icon in the toolbar. When I go to reopen SC from this icon it opens the 1918 version. What can I do? Thanks |
[2019-08-01 08:53:44] |
Follow the instructions here: Software Download: Setting up Shortcut to Sierra Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
