Date/Time: Mon, 21 Sep 2026 20:26:21 +0000
[Programming Help] - ,,,set counting to column,,,
View Count: 786
| [2019-07-30 10:12:24] |
| User865284 - Posts: 4 |
Hi , I need help to Spreadsheet System for Trading how to set counting to column P ///start J42 / stop - reset J43 Thank you |
| [2019-07-30 11:46:08] |
| Sawtooth - Posts: 4354 |
The easiest way is to use an event or signal in a Formula Column to create an incrementing variable. Here are some examples: Spreadsheet Example Formulas and Usage: Persistent and Incrementing Variables |
| [2019-07-31 15:29:28] |
,,, I've already tried .... /// not count correctly //// Thanks for help |
| [2019-08-01 08:21:22] |
?? is another way / formula... ?? how to count bars / time /// ,, in J42 J43 is time value ../// thank you |
| [2019-08-01 12:18:55] |
It looks like the incrementing variable is not being reset with a TRUE in L3.=IF(L3, 0,IF(OR(K3, P4 > 0), P4 + 1, P4)) This formula counts correctly if there is a TRUE somewhere in L3. You'll need to reset the variable with another event. The first IF statement resets the incrementing variable to 0. The second IF statement begins the count. |
