Date/Time: Sat, 15 Mar 2025 02:39:41 +0000
custom time frame
View Count: 2328
[2019-07-30 04:09:25]
Nimo2006 - Posts: 3
Dear support
thanks for giving chance for trying Siera Charts , please i would like to ask
1- how i could make a customized time frame ? ( i.e how i can show a time frame of 36 hr , 1800 min or 25 Day as example ? )
thanks in advance
Regards
M.A.Mahmoud
[2019-07-30 18:07:44]
Refer to this page:
Changing Chart Bars Period
[2019-07-30 23:03:48]
Nimo2006 - Posts: 3
No Answer for my question yet.
[2019-07-30 23:38:18]
Yes this has been answered at post #2 above. We linked to the relevant documentation for this.
[2022-07-14 18:19:01]
sourdubber - Posts: 52
I have a question about setting up a 1 minute chart with different start/end time.
Normally, time-based charts begin exactly at the zero-second mark, eg. starts at xx:01:00 (hour:minute:second) and ends at xx:01:59.
Here's my question: is it possible to start the bar at xx:01:05 and end at xx:02:05 instead (eg. delay or precede by x seconds)?
[2022-07-14 18:45:42]
John - SC Support - Posts: 38678
Yes, you can do this by setting the Start Time for your session to be offset by that amount. For example, if the normal session start is 08:30:00, then you would instead start the session at 08:30:05 to have the bars start at the 5 second mark.
