Date/Time: Mon, 03 Mar 2025 20:44:44 +0000
ZigZag Volume Display
View Count: 583
[2019-07-30 03:16:27] |
Gustavo - Posts: 74 |
Is it possible to display the ZigZag volume when using historical charts? Currently using the "default" settings setting the "volume to accumulate" to "Ask Bid Volume Difference" and the "Display ZigZag Volume" to "Yes" but only getting Zeros. Pleas advise.
[2019-07-30 18:08:49] |
You cannot access Bid Volume and Ask Volume through Historical Daily charts. You need to use an Intraday chart. Refer to: Chart Session Times: Creating Daily Bars with Custom Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
