Date/Time: Mon, 03 Mar 2025 20:37:15 +0000
Hand Tool
View Count: 571
[2019-07-29 18:40:24] |
User550721 - Posts: 3 |
Helo im using PKG3 with AMP and I noticed that the hand tool that moves the chart and background up and down does not wo. is that feature only available on PKG5? if not how do i fix it to move chart up and down? thanks much please email respose to attention109@yahoo.com
[2019-07-29 19:06:08] |
Refer to the documentation for this tool here: Chart Drawing Tools: Hand Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
