Date/Time: Sat, 01 Feb 2025 18:57:42 +0000
Session time discrepancy
View Count: 654
[2019-07-29 16:55:44]
User317207 - Posts: 1
Pulling up two charts of emini s&p 500 (f.us.epu19), I came upon a session time discrepancy. I placed Chart 1 with the session times from 1500-1400 and Chart 2 with the session times from 0630-1315 and included the evening session from 1500-0630. On Chart 1, the first 30 min period shown on 7//25/19 at 0630 shows the high of that period as 3017.75, but compared to chart 2 the first 30 min period high is at 3016. Also the last period and the close are different. I wanted to know why are these two charts different and how can I fix Chart 2 to show the same information as Chart 1.
In addition, is there a way to have a charting session times 1500-1400 but separate the day session and evening session? Also is there a way to change the colors of the evening session but retain the value area and poc, but just change the colors differently from the day session's colors. The only way I see on how to change is by changing the entire tpo into one solid color, but I don't want that.
Thank you for your time and help!
imagechart 2.JPG / V - Attached On 2019-07-29 16:47:59 UTC - Size: 333.38 KB - 365 views
imagechart1.JPG / V - Attached On 2019-07-29 16:48:08 UTC - Size: 248.02 KB - 269 views
[2019-08-01 03:26:10]
Make sure the Evening Session for Chart 2 is set to end at 06:29:59.
We are not sure we understand what you are asking here, but if it is whether you can have separate TPO profiles for the Day and Evening Session, the answer is Yes. Refer to the instructions here to do this:
Time Price Opportunity (TPO) Profile Charts: Displaying Separate Profiles for Day and Evening Sessions
It sounds like you want to have a single TPO for the Day and Evening Session, but with different colors for the letters. This is also supported. Refer to the documentation here for the TPO Letter/Block Colors - note specifically the option for Separate Colros for Day and Evening Sessions:
Time Price Opportunity (TPO) Profile Charts: TPO Letter/Block Colors
