Date/Time: Sat, 01 Feb 2025 16:45:36 +0000
Issue wiht 1958 and 1959 version I don't not why my past two request disappeared
View Count: 676
[2019-07-29 07:44:11] |
User657944 - Posts: 173 |
Hi I found and issue on 1958 and 1959 when I go to global settings>chart settings the platform freeze and I need to close it with CTRL+ALT+DEL and this is not happening with 1941 through Transact and it never happened in the past too.Could you please take a look? thx
[2019-07-29 10:20:02] |
User90125 - Posts: 715 |
Answered here: Dialog Not Displaying Issue |
[2019-07-29 10:24:54] |
Really strange what happened the post was not visible and the answer too...anyway thx I will test the 1960 and let you know asap Alberto |
[2019-07-29 10:30:50] |
Great Job! It works Thx Alberto |
