Date/Time: Sat, 01 Feb 2025 18:46:08 +0000
access flat to flat trade data with acsil
View Count: 806
[2019-07-28 17:12:29] |
onnb - Posts: 662 |
These two below provide summaries with fill to fill. sc.GetTradeListEntry() sc.GetTradeListSize() Is there any chance or any future plan to provide flat to flat support for these ? |
[2019-07-28 22:41:33] |
These have been added in a recent version but they are not fully documented. Refer to: sc.GetFlatToFlatTradeListEntry() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-03 06:53:22] |
onnb - Posts: 662 |
Are there future plans to add more fields to s_ACSTrade ?
[2019-08-03 12:02:16] |
What fields do you need specifically?
