Date/Time: Mon, 03 Mar 2025 20:58:24 +0000
Scale chart issues
View Count: 599
[2019-07-28 06:44:22] |
User604531 - Posts: 4 |
Hi, I have issues when i make scaling chart with hand tool, its dont move chart to the Y direction, only move to the X direction. I have the Sierra platform on my desktop comp it's work right, but on Macbook (Parallels desktop) with same settings it's not work. Can you help me please with this? Thanks in advance. Vasily |
[2019-07-29 18:56:11] |
Refer to the documentation for this Tool here: Chart Drawing Tools: Hand Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
