Date/Time: Sat, 01 Feb 2025 16:41:47 +0000
[Programming Help] - Trade activity log shows high of 8038.5 and low 1577.5 during position
View Count: 511
[2019-07-26 21:49:22] |
User506444 - Posts: 7 |
Almost as if two symbol got mixed up. Bugs can't be correct unless programmers know about them.
Sierra Charts190702.jpg / V - Attached On 2019-07-26 21:48:16 UTC - Size: 76.36 KB - 282 views |
[2019-07-27 01:00:06] |
Most likely that is faulty data from CQG due to an incorrect or no multiplier value they gave in the security definition. It is not something we can help with. Consider using this data feed instead: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-27 01:00:41
