Date/Time: Thu, 06 Mar 2025 20:46:24 +0000
Denali Data Feed
View Count: 755
[2019-07-26 18:23:31] |
TimCPA - Posts: 1 |
Hi, How do I get my charts to be real-time? I don't see any instructions. Need help.
[2019-07-26 18:37:04] |
John - SC Support - Posts: 38450 |
It looks like you are using TD Ameritrade for your Trading Provider. First, make sure you have gone through the setup instructions to connect to TD Ameritrade. This is here: https://www.sierrachart.com/index.php?page=doc/AmeriTrade.php#SetupInstructions Then follow the instructions here for an understanding of how the Denali Exchange Data Feed works with your TD Ameritrade setup: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#IntegrationWithTradingServices For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-26 19:06:09
