Date/Time: Sat, 01 Feb 2025 16:51:51 +0000
Simple way to set alert on total account profit loss?
View Count: 859
[2019-07-26 16:48:58] |
osaga - Posts: 53 |
Hello Is there a simple way to set an alert to go off when say the total account is down -$300? Is there a way to do this without using a function? Thank You |
[2019-07-26 19:07:33] |
Yes, use this particular study: Account Balance Graph - External Service And then you can write a formula to check for a particular value: Study/Chart Alerts And Scanning Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-26 19:08:24
